E32 730iL ABS warning light on.
AAM
My ABS warning light lit up ( yellow/orange colour ) permenantly on the instrument panel display until the engine is switch off. this started about 6 mths ago...... ( never bother to check since i didnt notice any difference while braking ).any idea what is it all about and the remedy ? :confused: thanks.
Not too many mechanics are keen to tackle this kind of issues as it takes time to trace the root of the problem.
I believe Albert Fang of WP Auto 0122017792 would have the patience to help you sort out this problem.
thanks.
The ABS system on E32 quite reliable and robust , look at potential cable snap around the brake area ( take out tire) where the ABS line are.
After period of time sometime the cable holder just wear off or when your mechanic replace some part like brake pad or whatever close to the ABS line .
I'm talking base on experience , 2 times already ........
Iqlima, which tyres...front or rear.....left or right ?
thanks.
its the ABS sensor cables. Cant say which one.. Go to any BM Specialist with either LAunch or GT1 diagnostic, they will be able to help
