Keano
- Oct 19, 2010
- 189
HiA couple of queries & hope to get some insights/pointers from the many Sifus here:-DashboardI've would like to repair several cracks on my E30 dashboard. Been advised that the process will involve rewrapping the whole dashboard unit by cushion/interior shop using some PU like material. Estimated cost is ~RM400.However, the dashboard needs to be 1st removed before the rewrapping can be done. Then subsequently install the dashnoard back. The cushion/interior shop do not have the expertise to remove & then install the dashboard back. Anyone can advise someone who has the expertise to remove & then install the dashboard back? Estimated cost?Roof liningI've would like to refurbish my E30's internal roof lining that is dirty & some signs of tearing. Been advised that the process will involve removing the roof lining material for a good old wash & then sewing back the torn bits. Estimated cost ~RM200.However, in order to be able to remove the roof lining, the cushion/interior shop said that BOTH the front & rear windscreens needs to be removed & then installed back. The cushion/interior shop do not have the expertise to remove & then install the windscreens. Anyone can advise someone who has the expertise to remove & then install back BOTH the font & rear windscreen? Estimated cost?Thanks in advance.
