teejay
- Dec 4, 2004
- 1,685
fabianyee;447186 said:can drift.. just that for hard core drifting, a snail and a light front end comes in handy...
but an extra gear also is good to have no....:top:
datsunnismo;447241 said:there's one mechanic told me. m42 is better thn m50 for e30 in term of weight distribution and better handling.
fabianyee;447380 said:hehe.. which mech is that?![]()
Anyway, M42 is ideal for good weight distribution and with that, it's more agile.. Can throw into the corner with less tendency for it to understeer.. However, it is down on power when compared to the 2.5 liter M50. U'll feel the lack in torque on the M42 as compared to the M50..
Well, can't have best of both world... Depends what you want the car to do more often loh...
E28driver;452905 said:If you are going through all the trouble of swapping engines, why settle for a puny m42 (no offence to the M42 gurus out there...)? The bang for the buck ratio is unappealing.
fabianyee;453051 said:the debate of M42 and M20B25 is aplenty on a lot of E30 boards.. hehehe... so it's pretty much split between the 2...
fabianyee;453027 said:Have u sat in a well sorted M42 converted E30? It's a 140hp pump-petrol-and-go engine. I've converted mine 6 years ago, done about 150,000km and no major issues... Daily drive, track days and long distance drives. Not sure what's the mileage of the engine when I got it but i reckoned it should be at least 50,000km. Water pump never need changing. Only changed some oil seals over the years. Just regular service needed. Duplex timing chain, so very little risk of it snapping.
Not the best engine for the E30 but it's one hell of a tough nut... It took all the abuse I threw at it..
M40 to M42 conversion is relatively straightforward compared to M50 conversion.
mizhan;453058 said:until i stumble upon a C2 2.7 halfcut that is.. :wink:
E28driver;453090 said:You can easily stroke your M20 to 2.8L or even 3.0L to give your Alpina rep the performance it deserves.
2.8L much easier to locate the crank lah.
al3dx;446949 said:yeah... once you get the M52 engine and plug in... you have to Jaga what engine oil you're using... cause of the Nikesil coating around the cylinder bore...
mizhan;453162 said:we really really need to sit down over drinks soon :top:
