Double DIY: Auto to Manual Conversion
stig;661591 said:
Iceman, yes I don't know if the gearbox is in working order but I have a standby box ;)! Else just rebuild la and puas hati!
To the rest commenting regarding the diff, I guess I learn something new everyday - might have to hunt for a diff as well. What's the average price for the 4 potter diff? I have a 6 potter 3.64 sitting around the house, might use that but have to get drive shafts :)
i think drive shaft will be least of ur problem... the housing may not fit...
If use 3.64 not only the driveshaft you should worry...the 3.64 diff a bit bigger so the longshaft must cut 1 inchi
Iylia H;661645 said:
what actually happened bro?
Eggie86;661649 said:
Hope your ride is fine bro.
Thanks for your concerns - I'm going to troubleshoot it this afternoon. I think it's a faulty fuel pump, or the faulty fuel pump circuitry...
UPDATE: I GOT THE CORRECT DIFF FINALLY
Thanks to all your advice, I realised that keeping the auto differential (4.44) on is a mistake. The correct diff ratio should be 3.45. Mtigo offered to let me buy his, thanks bro!
THE DIFF:
3.45:
