Damaged OEm rims - where to fix?
Hi All,
Just sent in my Type 162 rims into Heap Soon Segambut to be refurbished. The fronts had quite a few curb rashes and the rears had a few stone chips. Total damage was RM150 per tyre inclusive of repairs for bent rims (all 4 had some minor damage). Collecting the rims next friday and will update on the quality of work done.
kvdavies;426028 said:
Hi All,
Got my car back last Friday. They did an excellent job on the refurbishment. Would recommend them to anyone looking for rim repair work.
Only small issue being i noticed my tires are losing some air pressure. filled up on friday and lost 1 psi on all 4 corners by the time i checked on sat. filled up on sat and again i lost 1 psi all around on sunday. repeated the step this morning and no surprise, lost 1 psi at each tire.
i normally check my tire pressure every month or so and i typically lose about 2 psi all around. is this normal or should i be checking for leaks?
Are you still on RFTs?
No. Am running Type 162 OEMs on Toyo T1-Rs all around. 225/40/18 (F) and 255/35/18 (R).
