Clutch Bearing for E36/E30
turbology
My tranny is making whinning noise when clutch is engaged.But when I step on it, the noise disappeared.So, first thing it comes to my mind, is to change the clutch bearing.1. the part store told me the clutch bearing is same for both E36/E30 regardless of engine size.Is that correct ?2. On the box, it says "made in france", made by SKP. Look sometihng like as followed. Is it correct ? Is very plastic-ish ?
Looking for inputs.Thanks.
can't recall about the plastic-ish ...but these can also be bough here locally ...innerpower do carry them ...
as for if it's the same for e30/e36 ...depends on what tranny you're running on bro ...
i had the same problem with my ex e30 m40. bought the same part from stuttgard or ortojaya. couldn't remember which one.
problem solved .
