Hi guys, i had a clucth problem. I see my clucth liquid tank is empty, then i look under my car and saw something is leaking near the gearbox. So i suspect its the Clucth Slave Cyclinder problem. I cant change gear at all, So is there a solution that i can still fix the Clucth Slave Cyclinder? Or just replace it with a 2nd hand or new one. http://www.bmwe34.net/E34main/Maintenance/Transmission/Clutch_hydraulic.htm. here the link for the clucth system. but if i can fix the Clucth Slave Cyclinder that will be good. If there no choice i have to replace with a new one. I might wrong. Maybe there is other problem so hope you guys could give some advice.. Thanks. I stayed in sabah so to get 2nd hand part is abit dificult here, my only resource is penisular.
