Chassis and engine classifications
ALBundy
Founding Member
Ever talked to somebody about BMWs? Of course you have. If you tell him/her you've got a 5 series he/she may ask what type. Then it dawns on you, 5 series could mean FOUR different types of BMW! An original late 70's model, the revised 81-87 car, the radically new 88-96 car or a brand spanking new 97 model. Now imagine you need to order a part from BMW. Clearly asking for a front bumper for a 5 series isn't going to get you far. Neither will the year as a 1996 5 series could be one of two models. What we need is a model code for both the car and the engine. People on the BMW digest also use these codes frequently to avoid confusing between models so knowing them is useful.If anyone finds errors or omissions please tell me. Eventually a dedicated page will appear for each model and engine, sleep is for wimps!Car Model DesignationsModel Year Cars 114 / E6E10 / E12 67 - 77 1502, 1600, 1602, 1800, 1802, 2000, 2002ti/tiiE10 was the touring three door modelE20 was the 2002 tii & turbo E3 68 - 77 2500, 2800, Bavaria, 3.0S/Si, 3.3Li E9 65- 75 2000CS, 2500CS, 2800CS, 3.0CS/i/L E12 72- 81 518, 518i, 520, 520i, 535, 525i, 528i, 530i, M535i E21 75-83 316, 318i, 320, 320i/s, 323i E23 78-87 725i, 728, 728i, 730i, 732i, 733i, 735i, 745i, L7 E24 77-89 628i, 630CS/i, 633CSi, 635CSi, M635CSi, L6 (highline) E26 78-81 M1 E28 82-88 518i, 520i, 524td, 525i/e, 528e, 533i, 535i, M535i, M5 E30 83-91 316, 316i, 318i/s, 320i, 323i, 324td, 325e, 325i/ix/is, M3 E31 90 on 840i, 840Ci, 850i, 850Ci, 850CSi E32 88-94 730i, 735i/iL, 740i/iL, 750iL E34 88-96 518i, 520i, 525i/x, 525td/s, 530i, 535i, 540i, M5 Z1 (E30) 89-91 Z1 convertible Z3 (E36/7) 96 on Z3 convertible and Z3 coupe (Z5) E36 91 - 99 316i, 318i/s/ti/tds, 320i, 323i, 325i/td/tds, 328i/s, M3,Z3 E38 95 - 2002 728i, 730i, 730d, 735i, 740i/iL, 750i/L E39 97 on New 5 series 520i, 523i, 525tds, 528i, 530d, 535i, 540i, M5 E46 late 98 Next 3 series E53 2000 X5 four wheel drive SAV E52 2000 Z8 roadster E60 2002? Next five series, same floorpan as E65 E63 late 2001 New six series at last! 635Ci, 645Ci, M6 based on E56 chassis E65 early 2002 Current seven series (the ugly one) E66 late 2002 Long wheel base E65 ? 2003 New light weight (1040kg) 2002, can't wait! Engine DesignationsNot all engines are available in all markets. For example, smaller engines tend not to be available in the US. Diesel engines were not available in the UK until fairly recently. Power figures are for european models, most older US engines tend to be restricted by emissions regulations.BMW Code Size(litres) Cyl Valvesper Cyl Power (bhp@rpm) Torque (lb/ft@rpm) BHP/litre Torque/litre Manufactured Bore x Stroke(mm) Timing Weight(kg) VANOS Used in Notes & Comments M10 1.5 1.6 1.8 2.0 2.0i 2.0tii 2.0 turbo 4 2 75 @ ? 85 @ 570090->98 @ 5250100 @ 5500125 @ 5700130 @ 5800170 @ 5800 ? 91@ 3000108 @ 3000116 @ 3000129 @ 4350131 @ 4500181 @ 4000 50 53.152.25062.56585 ? 56.96058656590.5 75 66 -> 69?71 -> 8768 -> 75E21 320i / E12 520i71 -> 7573 -> 74 82x71 84x7189x7189x8089x8089x8089x80? Chain 82 No 1502 1600-21802, E21/E30 3162002, E21 3202002 tii2002 turbo 2002 turbo was world'sfirst production turbo. 2002ti had 120bhpAlso in E21 316, 318i, 320/4, E30 316 M20 (little six) 2.0 2.0i 2.3i2.5i2.7eta 6 2 ? 129 @ 6000 143 @ 5300170 @ 5800125 @ 4250 ? 120 @ 4000 151 @ 4000167 @ 4000177 @ 3250 ? 64.562.26846.3 ? 6065.766.865.6 77->92 80x66 80x6680x76.884x7584x81 Belt 117 No E21 320 E21 320i/6, E30, E34E21/30 323i325i, E34 525i325e,528e Head bolts can be a problem. Eta is lower rpm fuel saver. M30 (big six) 2.5 carb 2.5i2.8 carb2.8i3.0 early 3.0 late3.33.5 6 2 150 @ ? 150 @ 5500 165?184 @ 5800 185->208 @ ?188@ 5800200->206 (euro)218@ 5200 ? 159 @ 4000 ?177 @ 4000188 @ ?192 @ 4000209 @ ?229 @ 4000 60 6058.965.761.762.760.662.3 ? 63.6?63.262.76463.367.4 73->81 81->8874->7781->87/81970s1987->93early 80s77/8 -> 93 ? ?86x8086x8089x8089x8086x8692x86 Chain 143 No E12 525 E28 525i, E23 725i E12 528, 2800/CSE28 528i, E23 728i 3.0CS/i/L,3.0Si6 cyl 530i & 730i3.3Li/633, 732i/733i535i,635i,735i Classic "big six". M102 3.4 6 2 252 @ 5200 279 @ 2200 74.1 82.1 84-> 86? ? Chain 145 No E23 745i M30 with turbo. Early versions wee 3.3. M40 1.6 1.8 4 2 102 @ 5500 115 @ 5500 105 @ 4250 122 @ 4250 63.8 63.9 63.8 67.8 87? -> late 93 84x72 84x81 Belt 81 No post -87 E30 316i, 318i, 518i, Pre-93 E36 316i, euro 318i. Replaced by M43 M42 1.8 4 4 140 @ 6000 129 @ 4500 77.8 71.7 89 -> 96 84x81 Chain 100 No E30/36 318is, Z3 Beware of proile gasketin pre 93 engines. M43 1.6 1.8 4 2 102 @ 5500 115 @ 5500 111 @ 3900 124 @ 3900 63.8 63.9 69.3 68.9 late '93 -> late 98 84x72 84x81 Chain 83 No Post '93 E36 316i, euro 318i (except Coupe), 518i Euro only,replaced M40 M43TU 1.9 4 2 118 @ 5500 133 @ 3900 62.1 70 98 on 85x83.5 Chain 83? No E46 318i all models inc. Coupe Replacement for M43. Has balancer shafts M44 1.9 4 4 140 @ 6000 133 @ 4300 73.7 70 96 on 85x83.5 Chain 102 No E36 318iS, Z-3 Improved M42 M50/M50TU 2.0 2.5 3.0 6 4 150 @ 5900 192 @ 5900240 @ 6000 140 @ 4700 181 @ 4700 (4200 for TU)225 @ 4250 75 76.880 70 72.475 89? -> 98 89? -> 9595 80x66 84x75? Chain 136 Single on TU 320i,520i 325i, 525iEarly US E36 M3 TU model had VANOS. I don't have earlier M50 figures. M52/M52TU 2.0 2.5 2.8 3.03.2 6 4 150 @ 5900 170 @ 5500 193 @ 5300241 @ 6900 140 @ 4200 180 @ 3950 207 @ 3950236 @ 3600 75 6868.975.3 70 727473.8 96 on 95 on 95 on96->99 80x66 84x7584x84? Chain 118 euro 140? USA Single Double on TU E39 520i E36 323i, E39 523i E36 328i, E39 528i, 728iLate US E36 M3 Iron block in US,Alloy in europe. M54 2.0 2.22.52.83.0 6 4 150 @ 5900 170 @ ?192 @ ?193 @ 5500231 @ ? 140 @ 3500 155 @ 3500181 @ 3500207 @ 3500221 @ 3500 75 77.376.868.977 70 70.572.47473.7 . autumn 2000autumn 2000-early 2000 ? Chain 126 Double '99 Z3, E39 and E46 six cylinder models 2.2 replaced 2.03.0 replaced 2.8 Based on M52. Shows what the M52 should have been! Main difference is double VANOS. M60 3.0 4.0 V8 4 218 @ 5800 286 @ 5800 229 @ 4500 295 @ 5100 72.7 71.5 76.3 73.8 April 92 -> 96 84x67.6 89x80 Chain 146 No 530i 730i 540i, 740i, 840i All alloy. M62 3.5 4.4 4.6 V8 4 235 @ 5700 286 @ 5700350? 236 @ 4700 310 @ 3900? 67.1 6576? 67.4 70.5? late 96 on 84x78.9 92x82.7? Chain 140 Single after 98 730i 540i, 740i,840i Improved M60 M70 5.0 V12 2 300 @ 5200 332 @ 3900 60 66.4 88-> 94 84x75 Chain 155 No 750il 850i Classic V12 M73 5.4 V12 2 326 @ 5000 361 @ 3900 60.4 66.9 95/6? on 85x79 Chain 150 Single after 98 E38 750iL ? Newest V12 S14 2.3 2.5 4 4 200 @ 6750 215 @ 6750 177 @ 4600 181 @ 4750 87 86 77 72.4 87 -> 89 90 -> 91 93.2x83.8 ? Chain 106 No E30 M3 euro Euro. Several models used. S38 early 3.5 6 4 277 @ 6500 286 @ 6500 238 @ 5000 245 @ 4500 79.1 81.7 68 70 79 - > 80 86 -> 90 93.2x83.8 Chain 146 No M1 E28 M5, M6 24 valve M30 S38 late 3.6 3.8 6 4 315 @ 6900 340 @ 6900 260 @ 4750 289 @ 4500 87.5 89.5 72.2 76 88 -> 91 92 -> 96 ? Chain 151 No E34 M5 Also called S38? S50 3.0 6 4 286 @ 7000 236 @ 3600 95.3 78.7 92 ->95 ? Chain 152 Single E36 M3 early euro S52 3.2 6 4 321 @ 7400 258 @ 3250 100.3 80.6 96 -> 2000 86.4x91 Chain 152 Double E36 M3 (Euro) Late model Euro. S54 3.2 6 4 343 @ 7900 269 @ 4900 107.2 84.1 2001 on ? Chain ? Double E46 M3//M Roadster E46 M3M Roadster has 321bhp. US version 333bhp or 315 for Roadster. S62 4.9 8 4 400 @ 6600 369 @ 3800 81.6 75.3 99 on 94x89 Chain 158 Dual E39 M5 Double VANOS. S70 5.6 12 2 380 @ 5300 406 @ 4000 67.9 72.5 94->97? ? Chain 165 No? E31 850CSi //M Tweaked M70 M21 Diesel 2.4 2.4 Turbo 6 2 86 @ 4600 115 @ 4800 112 @ 2500 155 @ 2400 35.8 47.9 46.7 64.6 85 -> 86 83-> 91? 80x81 Belt 126 No 324td, 524d/td Never available in UK. Was used by Ford.in US. M41Diesel 1.7 TD 4 2 90 @ 4400 140 @ 2000 53 82.4 95 on 80x82.8 Chain? 108 No E36 318TDS Cut down 2.5tds M51 Diesel 2.5 TD 2.5 TDS 6 2 115 @ 4800 143 @ 4800 162 @ 2400 206 @ 2200 46 57.2 64.8 82.4 95 on 80x82.8 Chain 132 No E36 325TD/S, E34, E39 TDS has intercooler M47 Diesel 2.0 4 4 136 @ 4000 207 @ 1750 68 103.5 98 on ? Chain 117 No? E46 320d Variable incidence turbo. ? Diesel 2.5 3.0 6 4 170 @ 4000 183 @ ? 258 @ 2000 300 @ 1750 68 61 103.2 100 autumn 2000 ? Chain 165 No? E46, E39 Replaced M51 M57 Diesel 4.0 V8 4 245 @ 4000 413 @ 1750 61.2 103.2 99 on ? Chain 192 No? E38 740d Variable incidence turbo. VANOS = variable valve timing.To convert from ft/lb to Nm multiply by 1.36 (100ft/lb = 136Nm).To convert from BHP to kW multiply by 0.735 (100 bhp = 73.35kW).Engine weights are for a dry engine with no manifolds, starter motor, alternator, etc. They will vary by 2 or 3 kg for different types of fuel injection and model year. US M50 had an iron block due to sulphur problems and is much heavier than euro. Anti-pollution kit will add a few kgs to earlier US spec engines.
Hahahhahaha damn long .... LONGEST POST AWARD Bro i think we have to classify according to model .. easier viewed ..cheers :D
saved from the old forum:M Series Engine SpecBy chanklI believed we discussed the specs of the M50/M50TU/M52/M52TU/M54 before but the 3 series forum has been pruned so all those info was lost. I just spent a bit of time reviewing the TIS (again) and compiled the following specifications information on the M5x engines. The number in hp are U.S number which typically is 1 or 2 hp less than what the other part of the world uses. I try to stay close to the CKD model so some specific model like E46 325Ci or E38 or E53 are not listed. Well, let see how long can these spec info survived in this forum.The M50 engine was first introduced in 1990 in the E34 525i replacing the M20 engine. In 1993, the M50TU replaced the M50 engine in the E35 525i and E36 325i. In this spec, the maximum torque arrive at a lower rpm compared to the M50 engine.M50B20 110KW/6000rpm, 190Nm/4700rpmM50B20TU 110Kw/5900rpm, 190Nm/4200rpmM50B25 141KW(188hp)/5900rpm, 245Nm(181lb.ft)/4700rpmM50B25TU 141KW(188hp)/5900rpm, 245Nm(181lb.ft)/4200rpm (E36)M50B25TU 141KW(189hp)/5900rpm, 250Nm(184lb.ft)/4200rpm (E34)The TU stands for Technical Update, which offer a new Engine Conrol System (DME 3.3.1) and the introduction of Variable Camshaft Control (through VANOS) which gave improved torque curve, lower fuel emissions, better idle quality, and lower fuel consumption as compared to the M50 engine.M52B20 110KW/5900rpm, 190Nm/4200rpmM52B25 125KW/5500rpm, 245Nm/3950rpmM52B28 142KW(190hp)/5300rpm, 280Nm(207lb.ft)/3950rpmThe M52B28 engine was available on the E36 328i and E39 528i in CKD form. The earlier batch of M52 engine incorporate a cast iron cylinder block while the later batch was make of alunimium silicone alloy. (I found out recently that the earlier batch of 328i use the same cylinder head as the M50TU. The different is in the number of holes for cooling has increased. There are other differences in the cam design and hydraulic lifters but I wouldn't go into details. Now I know why we don't hear M52 engine overheat that often). Engine control is via the Siemens MS41.1 system.When the E46 was launch in 1999, the M52TU engine was introduced in E46 323i, E46 328i and the E39 528i. The major changes in this Technical Update is the redesigned crankcase, modified pistons, Double VANOS for the camshaft drive, and Siemens MS42 DME syste. Later the E39 523i was introduced with the M52B25TU engine.M52B25TU 126KW(170hp)/5500rpm, 245NM(181lb-ft)/3500rpmM52B28TU 144KW(193hp)/5500rpm, 280Nm(206lb-ft)/3500rpmIn 2000/2001, the M54 engine replaced the M52B2xTU engine. These are available in the E46 320i, 325i and 330i, E39 525i and E39 530i. Interesting to note is that the E36/7 Z3 2.5 and Z3 3.0 also uses the M54 engine!M54B22 125KW(170hp)/?, 245Nm(181lb-ft)/?M54B25 141Kw(189hp)/6000rpm, 244Nm(180lb.ft)/3500-4750rpmM54B30 170KW(228hp)/5900rpm, 298Nm(220lb.ft)/3500-4750rpmNoticed the range of rpm for the torque. I remember 3er mentioned something on the infinite variable camshaft control. I have yet to dig up more on that.The development objectives of the M54 engine were to reduce emission and fuel consumption levels while maintaining power and performance compared to the M52TU six cylinder engines. In the M54B30 engine, the changes include shorter skirt pistons, forged crankshaft, higher lift camshaft, shorter ram tubes intake manifold, slightly large injection valves. On the M54B25 engine, most of the features in the M52 engine were carried over. New on the M54 engine is the use of Siemens MS43.0 engine management system which is an electronic throttle control system adopted from the ME7.2 system on the M62 engne.It is tough going through all the spec! The version I had don't have a complete picture yet. Anyone want to do some home work on the M4x or M6x series engine spec?
also saved from old forum: Cracking the Codeby CircusCow Engines Code Cyls Capacity ValvesM10 4 1.6,1.8,2.0 8M40 4 1.6,1.8 8M42 4 1.8 16S14 4 2.0,2.3,2.5 16M43 4 1.8 8M44 4 1.9 16M41 (Diesel) 4 1.7 8M20 6 2.0,2.3,2.5,2.7 12M30 6 2.5,2.8,3.0,3.2 123.4,3.5,3.5tM50 6 2.0,2.5 24M70 6 5.0 24S36 6 3.6 24M88 6 3.5 24M52 6 2.0,2.5,2.8 24S50/B32 6 2.9(E36 M3) 24S50/B30 6 3.2(E36 M3) 24M21(Diesel) 6 2.4 12M51(Diesel) 6 2.5 12M57(Diesel) 6 3.0 24M60 V8 3.0,4.0 32M62 V8 3.5,4.0,4.4 32M73 V12 5.4 24S70 V12 5.6 24S70/2 V12 6.1 48--------------------------------------------------------------------------------Badgingi Fuel injectedCSi Coupe Sports injectedCi Coupe injected ('70s)Ci E46 3 series convertibletd Turbo dieseltds Turbo diesel with intercoolerd Common rail BMW diesel modelse 'eta' economy engine in the 525eiX Four-wheel driveXi Four-wheel driveSE Special EquipmentM3 Motorsport 3-SeriesM5 Motorsport 5-SeriesM6 Motorsport 6-Series, correctly known as the M635CSiB3 Alpina 3 SeriesB10 Alpina 5 SeriesB12 Alpina 7 Series and 8 SeriesM-Technic Motorsport styling, suspensionBaur E21/E30 3-Series CabrioletL Long wheelbaseti 3-Series Compact--------------------------------------------------------------------------------Cars3-Series E21 3-Series (1975-1982)E30 3-Series from 1983E30/5 3-Series TouringE30/16 3-Series with four-wheel driveE36 3-Series from 1991E36/2 3-Series CoupeE36/5 3-Series Compact from 1994E36/3 3-Series Touring from 1995 (with M52 engines)E46 Current 3-Series from 19985-SeriesE12 5-Series 1972 onE28 5-Series from 1981E34 5-Series from 1998E34/16 5-Series with four-wheel driveE39 5-Series from 1996E60 5-Series from 20037-SeriesE23 7-Series from 1977E32 7-Series from 1987E32/2 7-Series, long wheelbase (iL) versionE38 7-Series from 1994E65 Current 7-SeriesE66 Current 7-Series long wheelbase (Li) versionCoupesE24 6-Series Coupe 1976-1989E31 8-Series CoupeZ CarsZ1 roadsterE36/5 Z3 roadsterSAV E53 X5--------------------------------------------------------------------------------TechnologySteptronic 'Manual' mode on BMW automatic gearboxesSwitch-tronic Alpina 'manual' mode for automatics using steering wheel shift buttonsShift-Tronic Alpina's clutchless manual gearboxVANOS BMW's variable valve timing systemDME Digital Motor ElectronicsCBC Cornering Brake ControlASC+T Automatic Stability Control and Traction ControlADP Active Driving PackageARS Active Rollover Safety SystemDBC Dynamic Brake ControlAGS Adaptive Gearbox SystemEDC Electronic Damper ControlEWS BMW's electronic immobiliser systemPDC Park Distance ControliDrive Central menu sys
The M54 specs look like UK specs.. Anyone know the diff between the UK specs and German/Asia spec M54s which make up the power difference. Heard that we've also tested out the power differences between Marco's ride (UK spec) and JPB/Chester's car (CKD).
