Good afternoon Bros,Need some advise/opinion about this persisting central locking (CL) problem.
1. I can activate CL using the key (original BMW pakai battery macam 10 cents syilling) but some time cannot unlock if park under hot condition (not necessarily outdoors because happened also in underground car park) or lock/unlock kereta banyak kali.2. If open door manually (cucuk lubang + pusing kunci), only driver's side can open and CL not working (pintu lain cannot open) even when I press the CL button near the gear. Why the manual opening tak activate the CL? Anyway to go around this setting because susah kalau this thing happen ... kena climb in from the driver's side.3. After travelling for a distance while pressing the CL button near the gear, suddenly the CL activated (semua pintu boleh buka).The only solution now is to lock + leave the car overnight and the next morning the CL working macam biasa. But the problem will come again at unexpected times and create inconveniences.Any feedbacks will be greatly appreciated.
Cheers.
