525i;657334 said:There is a MP3 changer from Alpine. Model CHA S634. It houses 6 cds and it is a direct swap with the original BMW CD changer. I bought it of a forumer a few years back but you should still be able to find it from ebay.
The factory BMW harness uses something called Alpine I-Bus. The Soundgate box converts I-Bus to M-Bus. The KCA-130B cable converts M-Bus to Ai-Net (Alpine's latest bus standard). The CD changer has an Ai-Net connector on it.
alxy;652926 said:My CD changer went kaput some time back. I'm thinking of replacing it with a 3rd party (e.g. Alpine) CD changer, one that plays MP3 as well. Anyone done this before? Recommended changers, place to do it & price?
Thanks!
haywire;657718 said:Be careful, BMW changer which was also made by Alpine uses i-Bus system, while the identical CHA-S634 uses Ai-Net. Its like trying to install a Mac-only hardware to a Windows computer. You will need an i-Bus to Ai-Net adapter to make it work.
Correct. Mine came together with this adapter.
haywire;657730 said:Btw before you buy new one, what happened with your old one? Tried fixing it like I did?
http://www.bmwclubmalaysia.com/foru...e-Edition-2003&p=590761&viewfull=1#post590761
alxy;657853 said:Took it out but still same problem. Maybe will give it another go again. My symptoms seem the same as yours. When you said "so what I did is move the part slowly back and forth a few times until it loosens up a bit (gave it a phisiotheraphy).", what exactly did you move around? The wheel thingy?
haywire;657856 said:Yes the wheel with the metal arm attached to it.
