Can a B8 for E46 6potter use in a 4potter E46..?
cythomas83
Hi All Sifus,Can a B8 for E46 6potter use in a 4potter E46..?what is the second hand value for this 6potter used B8..?thanks a lot :)
Can for the rear but the front will look higher coz different engine weight
that's ok becoz i will use eibach pro-kit springs... :)
so it can be fitted to my E46 4 potter right?
is the eibach for 4 pots or 6 pot?
If you use an absorber that is design for a heavier engine (car), chances are the car will feel a little "skippy" on uneven roads, due to lesser compression on the absorbers. Suspension development takes into account the weight of the engine, that's why 4 pot and 6 pot springs and absorbers are different. Can you use it? Yes, definitely but it won't be the optimum setup.
