Camber problem
mikeraj04
Dear sifu's I have this chember problem recently where i change my front tyre's the left side the chember is very bad so the mech. told me no point doing Alignment ask me to check with BMW specialist or BMW service centre, pls help..
e46's camber can be adjusted....but require a special tool. Not sure if the specialists have it as most dont... :(
Camber go negative side common issue in e46. Sometime adjust camber to max but still its on negative
side. I believed its due to mechanical issue. Knuckle bearings and all suspension linkages may contribute
too.
Thanks bro Iceduke/bro arifferio,
will take the car this week for checking the Knuckle bearings and all suspension linkages
I have the same problem now on my left wheel... hurmmm still yet unsolved but my alignment guy manage to balance the car to a linear movement not perfect but enough :) Go to a good Engineering Workshop... most can solve it better than any workshop/alignment guys as they can even salvage and repair major accidents...
thanks bro, yes im going to the alignment guys for help me slove this problem.......
