Brake leaking
jumper det
Hello to all bimmerianz,,My rear drum brake on right side got some leaking problem and i need to refill my brake fluid from time to time.Can anybody here advise what are the cause of the leaking and what do need to repaired because i'm planning to do it with my friend help at bawah pokok garage.... :4:
it's your slave pump.. change it, but usually change both sides, then even pressure..
like pussy said.it's the slave pump....replaced both lh and rh pump on my e30....though not simultaneously.a word of caution....don't overtighten the rigid hydraulic line to the pump as the pump casing might break....ask me how i know....he he he....:wink:
