AzamDatoMohd
- Jan 19, 2008
- 358
BMW M5 - E60 HAMANN Full Edition RaceExterior An exterior of the car was introduced to the publicity in two colors (mat black and blue). The most radical change on the bodywork of M5 is its general broadening – so called Wide Body. A front bumper is connected with a mask (typical for the BMW cars). The bigger hole for an air intake to the cooler and smaller holes for disc brakes, are situated in the bottom part of the bumper. The broadening (wide body) is used to the off-take of a warmed air from front brakes and for the intake to the rear ones.The rear bumper is redesigned to the whole shape of a BMW car. A diffuser (prevents air turbulences behind the car) is situated in a bottom part of the bumper. Four oval 76mm Duplex exhaust tips are installed at the side. There are sensors on both bumpers which help to park better. Also we can find decent but sporting spoiler on the trunk door. There is also a spoiler in the window which is optically extending the roof. Hamman also changed stock mirrors to the carbon ones with the blinkers. Also stock wheels replacement is one of the exterior changes. They are black alloy wheel discs with dimensions 9x21” in the front (255/30 tires) and 10,5x21” in the rear (295/25 tires)
InteriorThe interior is in the red-black style. There is a red colored carbon is used on the steering wheel, a center of the console and other parts.The seats are coated with a quality leather (also in red and black). They are also heated and ventilated. Stock pedals was removed and replaced for the sporting Hamman pedals.Performance tuning: The performance tuning: The 5 liters, 10 cylinders engine hidden under the red carbon cover was improved by the HM/M+60 sporting kit (a re-programming of the control unit, a removal of the limiter, an air filter, a catalyzer ). This has caused an increasing of the performance from 507hp to 537hp (347kW).The modification of the heads of cylinder and the exhaust manifold has increased the performance to 567 hp (417kW). A maximum torque is about 533Nm and the top speed is 320kmph. That’s nice, isn’t it?Regards,Mohd Norazam Dato' Muhammad @ Zack'sFXCM MALAYSIA BERHADRAPID MERCHANT GROUP OF COMPANIESBMW | HAMANN Sports E60 - Sapphire Black - UK Spec
