t2ribena
Club guest
- Sep 9, 2006
- 1,773
- 38
AC525;429959 said:PS2 cornering not as stable as compared to RFTs think due to their stiffer sidewall... i reckon only 19inch normal tyre can match de 18s RFTs sidewall stiffness and cornering stability... but at the expense of comfort... if only someone can tell me whether 19inch rim with normal tyres will be more comfortable than 18s with RFTs? or would it be the same or worse off?
This will aid me then next time my PS2s wears off and due for change...
i have one set of type 124 on Bridgy RE050A RFT and one set of type 166 on Michelin PS2...
i use both alternately and based on my personal opinion is that the 18" RFT are very bumpy and especially thumpy on small cracks on the road or sharp bumps...but for slightly uneven road it is more comfortable than the 19" PS2 which becomes very unsettle when successive uneven surface on the road...
cornering stabilty the RFT win over the PS2 but the RE050A grip on wet sucks...
by the way mine is on the M-Spok suspension...so what ever setup also not comfortable...
