etquah;460529 said:You are absolutely right !! IF you can get use to it.
astroboy;460530 said:I have been practicing this for the past 3 years... theories goes as far as the classroom door. After the door, its all practice and getting used to it.
How close I sit in front of the steering? Look at it this way, my missy (shorter than me ) gets into my car, no need to adjust seat... yup! That close.. :24:
Even the Kongfu hand when turning steering also took me quite a while to loose the habit..
Casanova;460531 said:The 1 thing that put me off from attending was that they don't let you use your own car...but if you're driving a stock 3 series anyway then i suppose it's worth it since you'll be driving exactly the same car.
turbology;460537 said:closer doesn't mean better leh...
It should be two hands on steering 12'oclock, both shoulder should touch the seat with no space. At 3-9 position, the arm will slightly curve. That is the correct method.
ALBundy;460551 said:Why is that so? Care to elaborate??
astroboy;460566 said:I think he's talking about nipple touching the steering la.. :24:
:26:
turbology;460676 said:No lah. Most likely belly touching the steering.
When sitting too close, is harder and slower to turn the steering.
The turn angle is less too.
