banjir dalam kereta!
ritdijkit!
hello there guys.....im a newbie here...driving an e30........been having this problem for almost 4 months now....the car is not a daily driver........everytime when it rains my driver side floorboard would be drenched in water....water would be dripping to the accelerator pedal and i dunno where it is coming from....brought the car the my mechanic but they cant locate the leak...any ideas??..i love to drive it but afraid of taking it for a spin coz it might rain......the weather is shitty these days!...
hi ritdijkit....most of E30 I know facing these problem..btw yours what year ? 87 & below lagi teruk..karat laa...
If you really want to know where the water came from, you have to take out the whole carpet & insulator/soundproof beneath..then only you can see how bad the condition is...he..he..he.. It's not an easy job, truly E30 lover will do it..I did it on both my E30....just love the smell of the wet carpet....
Then only you send it to workshop to do welding...so you wont be cheated by the ketuk body guy..like I had during my early years with E30...
Hope it help..happy motoring..cheers..
Dude,
Try checking your water drainage...it could be clogged with leafs and debris causing the water to overflow. Also check the sealing for you accelerator pedal. It could have just worned our, causing water to trickle in via the pedal.:)
Hope it works. :)
water drip when it rains with car on the move or stationary(when parked?)
car stationary - remove battery and check beneath it.a holed corrosion will make water drip over the accelerator pedal.(my personal experience)
car moving - check the wheel well for corrosion
thanks for the responce............mine is 84 model.......i think the water is coming from the water drainage......wait..let me just have a look first.....busy la these days!....cheers!
How's your car now? still banjir ka?:)
also try not to put wet payung in the car, can banjir if do it always
vinson;159372 said:
Dude,
Hope it works. :)
My E30 also having the same problem - both the driver side and front passenger side.They are soaked with water during rainy days - worst if the car is stationary !
Mine is 1986 model.
BTW, where is the water drainage/channel located ?
Thanks.
aiyo...my car front windscreen rubber i think need replace liao also
last week 1 heavy downpour got few (n i mean jus few..haha) drips down above steering
anyway, will need to look other place for leaks (if any) too
waaa.... after reading all the postings, there are many possibilities:
1. windscreen rubber hardened
2.drainage channel clogged......then overflow...
3.front panel/firewall rusted
4.rusted at the base of acc. pedal
5.rusted at the floorboard,
6. wheel arch rusted
7.seepage from the doors, doorcard reput , plastic covering inside doors koyak.
8. water from gf jeans n shoes.........hahaaaaahaaaaaaaaa....
All related one.......:rock:
