Lol. I had the same problem and it really drove me crazy. I initially just stuffed some tissue paper into it. I later replaced the tissue paper with some insulation material (i.e. something akin to rubber strips).
Done!!! Managed to get this strip of Black foam rubber. about 1cm by 2 cm thick. Cut out appropriate length to fit the panel where the Middle brake light is housed in. Stuffed the strip in the Gap between the panel and the windscreen.
i drill a few pilot holes from under the panel (from inside the boot, upwards) and used a few self tapping screws to secure the whle board down, nice and snug....
Originally posted by gwumpkus@Oct 31 2005, 02:52 PM i drill a few pilot holes from under the panel (from inside the boot, upwards) and used a few self tapping screws to secure the whle board down, nice and snug....
Wow... very good fix. Too technical for me tho... heh heh
Anyway... I still have about a foot of that black rubber foam strip. You only need about 6 inches, so can fix 2 e36s. Anyone... PM me if you want it and I give it to you lah... FOC!
