Ok Guys, Anybody could help me with this...1. Everytime I take a left corner (either sharp or sweeping) as long as there are uneveness or small holes on the road, there's a loud thump sound from the right side, the sound is like it's bottomming (strong thuddd) and you can feel the judder on the steering. I don't have the same problem when I took a right corner/turn. What can be the cause, I was told by one shop when doing the alignment that the right steering rack dah longar/out. Is this true.. If it is, what alternative do I have, overhaul the thing as this can be done quite cheap (although price varies from asking), buy a recon or new one (will cost around RM2k for the new, am I right).Anybody experiencing the same problem before.2. A different problem, everytime the car move from stand still or from rolling, whenever the auto gear change (if I'm correct its from 1st to 2nd or 2nd to 3rd), there will be a slight vibrating to the rear side, as if you're feeling that its coming form the shock, or the feeling of going thru an uneven road for a few second. Is this the drive shaft, am I looking at a bigger problem later. What can remedy the thing. Can I put in molyslip in the rear axle?? as precaution/solving it??
