To all Astro Owners, please be aware that there are some bogus technicianoperating in Klang. It actual happened to me.My Astro could not receive any transmission and hence my wife call the AstroCustomer Service to report and complain. OK, they say that they will sent a service personnel to come and have a look. True enough, 2 person came andsay that they were sent by Astro to look into the complaint. After checking, they mentioned that the decoder is faulty and need to be replaced. They cost of the new motherboard is RM165 plus RM50 call charge. Reluctantly, the sum was agreed and instead of replacing the motherboard, the whole decoder is replaced.i.e. One to one replacement. Most of you would think this it reasonable but honestly, it is NOT. (Why? I will tell you later).However, after 1 week, the "New" start to give problem and of course, you willcall Astro again to complain.. (Who else do you call?)Again, 2 person comes and after checking they say that the decoder is faulty and need to be replaced. Of course, we mentioned that the deconder was just replaced only a week ago and it should be replaced without any cost. Ok, they say no problem but show us the receipt as a proof. My wife show them the receipt and they say that the receipt is not official. Actually, the receipt look like the receipt that you can buy from any stationary shop. The first technician said that the company have run out of reeipt book andwill issue a temporary receipt. Permanent one will be sent later. :listen: Anyway, to cut the long story short, we kena con by some bogus technician posing as Astro technician.OK as advised by Astro "Real" technician.1. All Astro Technician carried ID card issued by Astro matching their name and IC.2. If Motherboard have to be changed, they are authorised to change only the motherboard. They cannot do a swap of the whole decoder. At the bottom of the decoder, there is a special number that ID the decoder belong to you. It is sticked to the bottom of the plastic casing. If you loose this casing, they can claim that your decoder is clone or not authorise by Astro.3. All transaction or billing must be issued with official receipt on the spot.4. If in doubt, please call Astro again that they have despatch the technician.BTW, the service is usually outsource to other company. Astro do not usually repair or attend to installation directly.FYI, the bogus technician have a scar on the right side of his upper lip. The question that come to my mind is:-1. How did the bogus technician get to know that you are having a problem with the decoder?2. Should Astro be held responsible for a "leak" in their customer service or theirService Agent Centre.3. Why is Astro not doing anything about the bogus technician? Apparently, there are several cases happening in Klang because the "real" technician also can describe the bogus technician. i.e the scar on the upper lip.4. How do we get some compensation from Astro?:thefinger:BTW, Astro charge RM110 for the Motherboard and RM50 for calling charge.
