leforte
- Nov 6, 2005
- 587
B33mEr;419204 said:And here i thought that we're discussing about engine performance mod for the benefit of everyoneand yes of course i can learn more by actions (does writing a cheque for performance parts and installation constitute learning?) if i install it myself which i don't have the skills, tools and experience so the next best thing is to ask those that do.
Fyi my car still is under warranty so i can't do jack squat when it comes to engine ... But it is an interesting subject to learn more about... Hence the questions. Plus it benefits you more as a business entity as it will gather interest from forumers regarding engine mods. So leforte i have no wish to engage you in another arguments as i am here to learn and share knowledge ...
P/s: Dyno sheets or pix of the said engine?![]()
i have no means of provoking you. i do admire your will to learn.
so here is a simple answer to your earlier question in plain english.
the engine is generating more power and torque from the standard 2.3 hartge engine thanks to the higher compression ratio which equals more air& fuel burn per engine cycle. the higher you compressed the a/f mixture, the harder the mixture ignites and explode to generate power. along with a 4 individual throttle body setup as oppose to the restrictive stock bmw unit that hartge uses, the air flow of the engine is increase and hence even extra power is generated from the based engine. hope this is easier to understand.
dyno sheet and pix available but they are the sole property of the owner. you may try chatting with him into showing it to you or a ride in the car.
