wan syahmi;417577 said:20k is not just for safc, its for everything if u refer to page 1.iam not tuning on dyno, if i do so, my computer will cut the signal from airflow and just use o2 sensor because if i go on the road , the fuel will lean. iam ever do at joshoua ( milennium motorsport)..after come back, i cannot use safc for normal.although if i remove my air mass, nothing happened.. afte reset everything just normal and i do street tuned,,much more power i got couse tune at real air temp, real load. my gb is auto.
no offence wan, i admire your guts to so called "tune" your ride with the safc, but its a futile effort in doing so and the bmw ecu will just reset itself after adaptation sets in.
i would highly recommend you seek proper profession help in getting your ride tune up with the proper tools via obd2 remapping and get the actual performance you ought to be getting from your 20k investment which, for now seems to be just add-ons that does nothing but damage to your engine.
Seriously, by just looking at your video, you car seem to be performing just like a stock unit at anything above 180kmh. are you kidding yourself with 240hp? Do note that with performance cams fitted, the car should be at a nice performance sweetspot at that speed/rpm and the car should be accelerating exponentially compared to stock, but your car doesnt seem to be doing so and seems to be running out of air playing catch up with that golf gti which is clearly out of your lead. you also mentioned you change the injectors with 330 unit. you do know the 330 injector is about 50% larger than stock right?, by just changing the injectors and no tuning, you car will be running lean and knocking which makes sense of your car's poor performance and check engine light blaring at you. :106:
bmw vs golf turbo
for your sake, please get help.
