Anyone can help me source for BC stalk?
anaksarawak
Official Member
I plan to do the same as our OM aidilj http://www.bmwclubmalaysia.com/forums/showthread.php?41073-DIY-E46-OBC-stalk-retrofit
Bro anaksarawak, the stalk is available at many chop shops. Condition may vary, bro kby88 bought his and was installed and coded during Borneo OTT last time.
Ok will hunt for one today
I plan to get it around RM100 ... Low demand but plenty in KL as per bros here
I m very sure ATSB got plenty of them. Price not sure.
Mine was bought for rm150 from a chop shop in Klang.
I also saw a few in a chop shop beside Zoo Negara.
If it is more than 150, just walk away..
Oh I forgot to add. While rare, these stalks can fail. Make sure you try out the movement of the stalk. Should be smooth. If possible, ask for warranty and make sure all the functions work when installed.
Hi bro anaksarawak, are you going to DIY? I intend to have the OBC stalk but being a dummie when it comes to DIY, i gave up. Maybe if you intend to DIY, we can do it together?
Sure lets DIY this together :) Easy DIY as we have the tools now need to source for the stalk
Thanks so much from UDM68 (Hon) for selling me his spare BC stalk... Yahooo!! DIY tonight or this weekend. :)
gendong;793889 said:
DIY during TT la tmrw bro......
Maybe I pasang first and DIY the coding with GT1 tomorrow as many of our bros here need coding tomorrow. :)
Bro, you can code using NCS Expert which is easier and faster than GT1.
Module to code is AKMB which is kombi or cluster, set to below
0574 BC ON-BOARD COMPUTER (OBC)
* 0001 aktiv active
0002 nicht_aktiv not active
Cheers
And our BMW Scanner 1.40 also can do the trick.
Under KOMBI module, just thick the OBC and save it.
up cho b?n
Am so happy that I have my BC stalk successfully installed and coded awhile ago.
Thank you to
Iceduke
Aidilj
Udm68
Kby88
Thank you to
Iceduke
Aidilj
Udm68
Kby88
Any pix? :top:
Darn.... my FC is so high! No thanks to my hill top condo and short drive to office.
I tried to remove the old stalk without removing the steering and slip ring as per UDM68 instruction but failed .... Hahaha I might not have his skillful hands
New stalk installed and plugged in to check if my pre coded with BMW Scanner 1.40 has activated the new stalk
WARNING! Never forget to screw back the centre steering bolt, otherwise you have to redo the whole process all over again. Dont pull the steering if your centre bolt is not secured otherwise you will damage your slip ring, I saw in other video that once the ribbons are out its hard to put it back.
Everything are the same as aidilj's guide but removing the airbag of my car (3 spokes) require the following trick
[video=youtube;_QRmnaQFuZQ]http://www.youtube.com/watch?v=_QRmnaQFuZQ[/video]
