Alarm System
Quikflyer
Apart from the lack of reverse sensor, my new ride ALSO doesn't come with an alarm system! Is it a norm for all 1ers out there on the road in Malaysia?? Should I be worried? :eek: :eek:
i was gone to accesories to install additional alarm system for my E46 - 320i but original still can used. just for additional security
whats the definition of alarm? my 320i has the locking thingy all but what is this alarm?
U mean siren la. You force open the door she doesn't scream la. But if no key, u can't hot wire to start the car ma... unless u bring ur own ECU lor..
Meaning we all ada IMMOBILISER.. :D
i think most continental cars dont have alarm, just the immo & central locking. maybe car theft isnt a problem over the other side of the world ? hmm.. but it really sounds funny to have Bimmers with alarm that sounded like the Protons/Honda/Toyota..
Mine doesn't have alarm too, it's normal.
I have the same issue as well, Quickflyer.
I read the manual book and saw that it's optional and only availale with certain model. It will sounds when the car detected certain tilting angle(when the car being towed) or interior activity(when you and your gf in the car after you locked your door).
So I thought only 116i doesn't have. But I am surprise that Gracetcp's 120i also doens't have. If the car have the alarm, the little transparent knob under the reverse mirror will be blinking in red.
Uses GSM Network
The alarm is fitted with a mobile telephone SIM card (not included), allowing the alarm to make and receive telephone calls. This also allows you to track the location of the car via the telephone signal. Any SIM Card can be used . You can monitor your car anywhere in the world!
Easy to Use
To use the system, just call the telephone number of the alarm, enter your pin number and a voice menu will guide you through the options. The pin-number system prevents unauthorized access to the alarm features. Calls can be made to the alarm from any telephone.
Telephone Alarming
Three alarming telephone numbers can be registered on the alarm. If the alarm is triggered, the alarm will automatically call the first telephone number within 13 seconds. This is in addition to the regular alarm (flashing lights, siren). If there is no reply, it will call the second number. The user can then reset the alarm, monitor the car, send a verbal warning to the burglars or immobilize the car all from the telephone.
Panic Button
Two emergency telephone numbers can be registered on the alarm. It is advisable to set these numbers to close friends/relatives. If you are in trouble - hit the panic button on the remote and the alarm will automatically call the first emergency telephone number. If there is no reply, it will call the second number. The user can then reset the alarm, monitor the car, send a verbal warning to the burglars or immobilize the car.
Remote Arm/Disarm
The alarm can be set using either telephone or the remote control. If the vehicle is fitted with central locking, this action will also lock/unlock the vehicle. If the alarm is set by telephone, then the alarm cannot be unset by the remote. This feature has many uses:
Someone needs to get in your care when you are away
You aren't sure if you locked the car or not
You lock your keys in the car
Someone steals the remote & keys - if you lock via the alarm, they will not be able to open or disarm the car with the remote
Remote Status
Call the alarm at any time to check the status of the vehicle.
Sms function
This alarm set have sms function.
Remote Monitoring
A microphone installed inside the car allows you to listen in to what is happening inside the car from your telephone. Thieves in/around the car will be completely unaware that this is happening.
Remote Broadcasting
By calling the car alarm, it is possible to broadcast your voice through the alarm loudspeaker. This can be used to give a warning to anyone near or in the car.
Car Location
You can track for your car location using gsm service provider to know your car location.(example like maxis friend finder service.)
Anti-tamper
The unit has a backup-batter which works for 7 hours. If disconnected from the power source, the unit will immediately call the registered telephone numbers to warn of the situation. The unit can still be traced during this time.
Anti hi-jack
In the event your car is hi-jacked - do not fight back against the hi-jackers. Instead, let them go and then initiate the anti-hijack feature by calling the alarm from any telephone:
Hazard lights will flash
After 10 seconds the hazard lights will start flashing , After 20 seconds, the alarm will start sounding and hazard lights will flashing, After a further 30 seconds, the car ignition will be cut-off, the vehicle will then be completely immobilised
The alarm will then sound continuously.
Car Locator
Pressing a button on the remote will cause the hazard lights to flash and the alarm siren to sound for 3 seconds. Just in case you can't remember exactly where you parked it !
Silent alarm mode
The silent alarm mode works just like the regular alarm settings except that if the alarm is triggered, the siren does not sound. Instead you will receive just the telephone call warning only.
Auto Hazard Lights
If any door is opened whilst the engine is running, the hazard lights will immediately start flashing. This is useful to warn other motorists that you are stationary and moving around the car. It is also useful when you have children in the car, if the door is slightly ajar, the hazard light signal on the dashboard will bring this to your attention.
Technical specifications:
1)GSM frequency: 900MHz and 1,800MHz
2) Voltage: 12V
3) Temperature: -20 - +65°C
4) Control distance: 20m-100m
5) Remote frequency: 315-316MHz’
This is what im using for my ride
Uses GSM Network
Easy to Use
Telephone Alarming
Panic Button
Remote Arm/Disarm
Remote Status
Sms function
Remote Monitoring
Remote Broadcasting
Car Location
Anti-tamper
Anti hi-jack
Car Locator
Silent alarm mode
Auto Hazard Lights
2) Voltage: 12V
Great!!:top:
but how much is it? do you need to carry another remote control?
i got it fixed for rm1500
up to u, u can lock using mobile phone as well
Hi ther , is the gsm alarm working fine ? I'm quite keen too.
What if i wanna fit in another alarm system eg clifford blackjax / gps monitoring. Will they gel ?
