Raymond@M-BeasT
- Feb 10, 2006
- 817
- 16
i check every week.
mee too kena... first time kena due to water hose leaking ...and now kena again, when i checked found there's leak mark at the radiator side, just a micro crack on black non-metal part (it's not plastic it's look like fibreglass)Originally posted by leakwoon@May 16 2006, 09:32 AM
who else does top up the water regularly here?
hmmmm![]()
Your wiper washer motor may be leaking. Happened to me.Originally posted by 3CI@May 22 2006, 11:26 PM
supprise today, my viper water tank water sudenly finish all (the water light warning) after i check, iizit the tank crack or have to top up once a week ? are the engine too hot to happen this ?
Originally posted by wglee+May 23 2006, 12:06 AM-->QUOTE (wglee @ May 23 2006, 12:06 AM)
have to back workshop again ! .. aiyo malas lah..Originally posted by wglee@May 23 2006, 06:21 PM
Cannot remember leh. I think it was around a hundred plus ringgit (got it done at AB).
bro leakwoon,Originally posted by leakwoon@May 23 2006, 08:18 PM
aiyooo
so how frequent u guys reflush n re fill the coolant with 50% distilled water?
i read manual is 4 years
we having same problem...Originally posted by leakwoon@May 25 2006, 07:35 AM
the light on for about 20 sec...then it disappeared!
have topped up once since last service..approx once every 5000kmsOriginally posted by 3er@May 16 2006, 01:07 PM
I top up twice a year only.
bro thanks for tatOriginally posted by tkew@May 29 2006, 05:08 PM
bro leakwoon,
i think u need to chk the hot pipe that goes to the aircon for hot air, coz your car have the hot air function. The hot pipe leaking may give you the problem that the water level is low coz the leak from the air con part not the engine. So when u chk the engine it is ok.
Hi, i am not sure if the structure of the M54 & M52 engines are the same but my E36 325 actually had a leak before but i couldn't detect the leak initially beacuse i thought all leaks comes near the radiator area but later on when i send it for checks, only then did i found out that there's still another metal t sharp bar below the throtte body that is leaking, it leaks slowly but surely. I had to top up water every 2 - 3 days then.Originally posted by chris2000@May 13 2006, 01:45 PM
This thing also happen to my E46 328. Previously own by my brother, he told me no need check radiator water since new but since last year, roughly every 3 months it needs top up else the radiator light will come on.
I suspect there might be a very small leak some where. Any ideas guys?
