My DSC warning (the one with triangle and car skidding aite? not too sure about the lights at the instrument cluster) light keep on coming out when cornering slightly harder after i changed my shock, spring and ARB. The car is very much in control when it happened (no apparent over or under steer). Anybody experience similar issue before can share what might be the cause, thanks. The problem is, when it happens the ABS kicks in and for a few seconds you can't apply the brake properly (I believe this is the function of the ABS). Some guys might wanna suggest driving slowly at a bent but I believe our UDM should handle better than a Vios that overtook (at the time) without any issue.
