C camaryp2000 Club Guest Joined Apr 30, 2012 Messages 3 Points 0 Apr 30, 2012 #1 what ideal pressure of tyre 215/45/17 for my BMW E36 318i
hammer1911 Club Guest Joined Dec 9, 2009 Messages 95 Points 6 Apr 30, 2012 #2 ideal 30 psi front and back
Z zeroed Club Guest Joined Dec 8, 2011 Messages 18 Points 0 May 9, 2012 #3 200-220 psi depending on stiffness preference... but that range common and safe for most setups, for normal driving.
jeffreyewe Founding Member Joined Nov 25, 2004 Messages 4,548 Points 63 May 9, 2012 #4 30-32 psi for normal daily home to office use, 28 psi for long distance use also depending on load and absorber setup.
Z zeroed Club Guest Joined Dec 8, 2011 Messages 18 Points 0 May 9, 2012 #5 Opps sorry... i meant 200 - 220 kpa
L lemonteastudio Club Guest Joined Jul 8, 2012 Messages 42 Points 0 Aug 19, 2012 #6 My 328i tyre 225/45/R17... 33psi You can refer back to the tyre pressure informtion tag on you b pillar ( open your door then you can find it )
JFT63 Well-Known Member Joined Aug 26, 2010 Messages 4,621 Points 48 Aug 19, 2012 #7 lemonteastudio;765471 said: My 328i tyre 225/45/R17... 33psi You can refer back to the tyre pressure informtion tag on you b pillar ( open your door then you can find it ) Click to expand... Thats the best...i always refer to that tag as well..
L lemonteastudio Club Guest Joined Jul 8, 2012 Messages 42 Points 0 Aug 20, 2012 #8 City & town driving +1psi, long distance drivinig +2psi... Try to fill in the pressure in cold condition (tyre in cold condition if possible)
