Air cond blower
ckhaw
I recently changed my air cond blower when my dash was taken out recently. However, the new blower, same as the old one, seem lazy and not putting out air fast enough to cool down the car. Even Proton air cond is much better than this, at least you can feel some air :) Any guys had encountered this problem before? Please help... Thanks!
Did you check the micro filter? Have it changed and see how is the air flow.
Goodluck
Thanks a lot guys, really appreciate it. Will do that.
Btw, does E28 air cond blower have transistor? According to my mech, he said there's no transistor, just blower motor.
Firstly, there is no microfilter 4 E28 blowers!
Secondly, nvr compare wif Proton a/c. They r da best!
Thirdly, go visit Naidu, Jln Gasing!
When ur mech fixed a new blower, most likely he used back da original a/c channels under da dashboard. After all these yrs, these units will begin leaking da blower's air be4 it reaches u. Throw dis units out, use flexible pvc conduits direct fr da blower to da vents. On top of dat, Naidu normally would add a relay 2 da new blower 2 make it run at its top.
My 525i blower runs dis way...even on normal hot afternoons, I would off it coz it get's very cold...yes, my temperature controller is always at da lowest :cool:
Sorry for the late reply, just got back from Aussie. Thanks wolverine, i'll go to Naidu. I can't agree more that Proton A/C are the best. Boleh masuk Proton A/C into E28? :)
Took my car to Naidu, after some testing, old blower unit still not performing too well. According to him my E28 didn't come with A/C when it was imported, the blower unit is from a Tiara (probably fitted by previous owner).
Installed a Super King blower, took out the 4500rpm motor swapped a 5000rpm motor in. Wahlaa... it's magic.
1. Super King Blower + Cooling coil (one whole set with switches, wiring, valves, etc) = RM 480
2. Coolant + Oil = RM 30
3. Workmanship = RM 70
Total: RM 580
Result: Puts a big smile on your face. Very strong blower, i would say like Proton A/C!
Thanks guys for all the help. You guys are the best!
