E34 Air Cond Problem
5series
Dear Sifus,Have you experience this on your air-cond??1) The air cond blower sound very loud when you turn to 3rd or 4th speed.2) It take long to get cold air (under the hot sun)3) When the car is at still, air cond is not cold4) Suspecting air leak by the side of dashboard, got a layer of mist (about an inch wide) between the dashboard and front mirror at night. Anyway to cure?Got a big problem with my air-cond, any doctor for it?? Have recently spent around 1K for that, but the pronblem still arise. :cry:
Who do you meet when you have aircon problems? Naidu...
As for your questions...
1. Yes.
2. Yes. Since my car is dark colour too. In fact, it is too hot, my aircon can just about cope up with the heat.
3. Was until I changed my aircon compressor.
Hi, Flash,
Care to share the address & tel of Naidu? So, you have solve the air cond problem oredi? How much was the compressor cost you?
I am no expert on aircons, but just to share some experiences.
Is the sound loud but small volume of air coming out of the vents?? This could be due to yr blower unit is dirty, get an aircon guy to clean/service the blower unit. Many drivers dont service the blower unit regularly.
Due to our outstanding outdoors temperatures coupled with the fantastic temperatures within our car under the sun, our UDM needs more time to suck in cold air. Will help if u drive the car faster to assist in the intake of fresh cooler air.
Same as 2, when yr car is at standstill, no fresh air is taken into the air-con system, so no cold air. One other thing to check while yr blower is being cleaned, ask the guy to check on yr fresh air intake flap. Normally, this flap is stuck in the open position (despite the dashboard says its closed). Get the air-con guy to close and seal the flap, eliminating heated engine air being sucked into the air-son unit, keeping the air much cooler faster.
Get the air-con guy to look at this while he is cleaning yr blower units.
Hope this helps, but then again, its no expert advice. Just ask for yr air-con guy to check all of the above. Most of the time, its the fresh air intake flap being stuck in the open positions that makes the air-con unit seem not working. Correct it, and it may even be better on yr air-con unit.
Flash, pls post or PM Naidu's contact and add la... and pricing reasonable??
Do a search in the forum for Naidu... his workshop is behind the Shell station on Jalan Gasing (next to the EPF PJ building).
Thanks guys! Shall get Naidu to check on my unit. My wife is complaining.........
Hmmmm, same same. Me wife cumplained first too... :D before I sent my car to Naidu's.
Looks like we are in the same ship. So, finally is your air cond unit in tip top condition with less shound when it's on high speed? How much it cost you?
Still a few more things to do... sudah blow budget for the month. Can live with what I have for now. Cooler than before and quieter too. But can be better.
