Yup, I have all these 3 symptoms now. Just thinking of try luck at some chop shop, if really can't get a good one, will have to go to BA then.wingzee said:A brand new DISA valve cost about RM750 at Bavarian Auto. Symptoms for failure are high fuel consumptoon, ticking noise near DISA & loud suction noise.
Is it easy to DIY removing and install it? Any special tool needed?jarance said:Before changing the DISA, just remove it and inspect it.
If the flap is loose, then change it.
Quite easy DIY.. Just need the following toolskw930 said:Is it easy to DIY removing and install it? Any special tool needed?
Checked with BA today, DISA no more rm750, now about rm900+.wingzee said:A brand new DISA valve cost about RM750 at Bavarian Auto. Symptoms for failure are high fuel consumptoon, ticking noise near DISA & loud suction noise.
What is your model?kw930 said:Checked with BA today, DISA no more rm750, now about rm900+.
Ai...think need to focus on chop shop hunting now.
Btw, i know DISA model for 330 is different, how about 320, 325.and 318 (not sure got or not)? Are they using same model?
