hehe... I always mis-understand others..
Thank you for your understanding..
You are not wrong actually to say cars are becoming more problematic/fragile compare to how there used to make cars, even the Japs are the same.
For instance, ABS and airbag warning indicators lit.. and so you say hey! why so unreliable? But they never have such things before. So are u saying you should avoid cars with ABS and airbag? How many Perdana is driven around with ABS light permanently lighted and owner just ignore it, if not unplug the indicator bulb, just because it takes RM1.8k to fix? ..and the car still stops fine..
Take a look at the growing electronics and electrical parts in a car, even the new Civic 2.0L is using electric power steering, no more belt driven hydraulic steering despite the E90 still uses belt driven hydraulic power steering..
.. but the E90 is using electric water pump and electric oil pump so engine can focus into powering the wheels than pulling all the ancillary devices... well, this is the direction for motor industry and even the Japs are following closely.
ECU problem? Then use carburetor car lor.. The Merc Kompressor has so much compressor problem but I still expect to see all future cars be equiped with it or turbo because force induction cars are more efficient car when in comes to consuming earth resources.
Foreman of course ask u to buy old models la, because new model they don't know how to fix ma..
Run Flat Tyre for instance, BMW introduce it in E90s and Mini back in 2005, and its been 4 years now. How many other manufacturer is keeping up with them?
The balance weight chassis for a 3-series is so sweet for cornering, and the stretch bonnet design with low over hang plus the kidney grille, Hoffmeister curve are candy to my eyes, "problematic" engine is secondary really.. :wink:
If you think BMW engine is problematic, go try our an Alfa..
