1 series wheel on e36?
speedevil7615
currently using 17" on e36.guys, think 16" x 7 ET44 will fit my e36?what is the offset for e36 btw? 35 ?
yes,they can fit.original rims 15 inch comes with offset 47.i used 17 inch before with 38 offset,no prob.lower offset will give u a problem at the rear wheel,rubbing with your fender.
The range +- would be 35-46 if I remember correctly, however offset depends on design and width. Therefore, the rim width has to be taken into consideration as well when comparing offset. You may fit higher or lower offset wheels but you might have to get smaller size tyres to avoid rubbing either on the inside (using higher offset) or outside (using lower offset). There are ppl running on ET12, ET15, ET20...etc offsets on their E36's so depends what you're looking for.
thks guy!
was asking bcoz avoiding to add spacer to it!
m planning an 16" wif 225 or 235, dont think 7" width can reach 245..
