Dear all....Kinda need your guys' help on this. My rear door (left) seems like there is 'bocor' where you can hear the wind coming in from the screen when I was on high speed. Anybody experience this and and idea how to solve this...help me guys
Funny. Have this problem with my backup car Proton Saga (no joke) front driver's door. It happened after the power window jammed up and I used my 2 palms to hoist up the glass forcibly. As a result the glass did not sit properly in the groove leaving small gaps through which air whistles through when I drive fast. My 2 sen worth, your glass is not sitting well on the rubber.
Check ur door seals (both, front and rear) and the window runners. The window runners get hard and shrink with age. Could be one of the reasons. You could try spraying silicone on the rubber to rejuvenate both. If does not work, means time to replace.
all the rubbers n seals have been sprayed with silicone but still the same . I planned to change all the rubbers later. do u have any idea the budget..
