I think a number of the other members as well bought the full mobility kit which comes with a spare tyre. You can order it from Eurotuner which is one of the club's vendor. Used to just carry the sealant for the tyre but during an excursion to the east coast, went through the usual trunk roads with a friend and he hit a bad pothole. Two rims bent and caused two tyres to go flat. Hence why I see the need for the spare tyre. If you travel a lot in the city then it is a little over kill
Hello All..I was told that the 12V mobility kit may not be powerful enough to inflate the tyre. Some even suggested just get one of those pedal pump which is good enough. Any comment? Thx
Got a 12v pump from QuickSave. Used it to pump deflated Naza Ria van tyres. Did its job fine. Just make sure you check at the earliest convenience all tyres at petrol pump. At least it does get you out of trouble.
The cheap ones though I found are useless.
