Wheel Alignment - E36
flash
Guys, have just sent my babe for wheel alignment and wheel balancing. Car is now tracking straight and true (yup, Chan, no more that slight pull to the left). However, I do have a small cosmetic problem... the steering wheel is not pointing straight. Since my steering wheel has an airbag and after running thru the Haynes manual, it is not an easy matter to just realign the steering wheel becos if it is not done properly, the airbag system may not work. Anyone done it before? And by the way, yes, the steering rack is aligned to the middle when the wheels are pointing straight. :dunno:
Its just a minor adjustment on a nut. Quick job under the car only. No need to mess with the steering wheel itself. Go back to your alignment centre.
