Whats leaking? M43 engine
anaksarawak
Official Member
Hi Sifu sifu...Notice the leak after my long drive to IPOH. Prior to this my car was checked and serviced, no leak. Can I delay this repair without much damaged to the engine?
Is the leakage serious? just make sure the oil dont kena your alternator and aircond belts, otherwise they will be damaged easily. Do check your engine oil level to make sure it doesnt decrease.
I was having leakage on my power steering hose too but my mech said the clip was loose, so he tightened it back and washed the stained hoses with petrol. He said drive 1st and see if it leaks again or not. Actually not leak but evaporate as claimed by him. But I just check the hose, there are signs on oil again...maybe time to change the hose. *sigh*
George...i"d seen worse than that...your leak sikit je tu, it won't damage your engine...
i think u need to change one of the gasket only, i also think its not serious unless u have rapid drop in engine oil
if possible... have it repair. if not, 2nd wife will get more angry!
err...maybe oil sump gasket issue....if that no need to worry..small issue... Mine got this problem too...havent fix coz sooooo mahal, not because of the parts but the upah ! so many things need to be remove and displace.
By the way, anyone have change this before? how much u kena?
