pussy;735465 said:previous owner of the car was a drug lord....
joking, blackcat and aidilj is correct... use hot water to clean it up. no issues.
bmw7833;735474 said:Do i need to replace the battery? Is it save to use? Will it cause further damage to my car?
pussy;735767 said:use la, the discharge from the battery has a vent pipe, should be discharge to the bottom which original has a hole down at the base.
maybe yours was not connected, so come out to the side la....
bmw7833;735770 said:Bro, i have one small pipe in that place, but how to connect?
I asked before and no one can answer me, is this pipe u meant?
http://www.bmwclubmalaysia.com/forums/showthread.php?38851-What-is-the-vent-tube-use-for&highlight=
astroboy;735777 said:Why is your breather hose hanging loose at the background of this photo?
MF Battery also got sulfuric acid keh.. still need breathing.
bmw7833;735784 said:... Do i need to paint the area to avoid further corrosion?
bmw7833;744255 said:Boleh kasi pinjam luit tak?
