just fixed and electric fans, but the temperature still raised over the half and a little bit of the temp gauge, is it normal?and can i take out some of the small coolant hoses which come out from the block and go into a metal multi joints which one side is for the coolant and another side is for the air, i suspect it might caused by the bad coolant flow. and what is the symptoms if the water pump is faulty?
