be careful when u do the testing bro. got a friend the car need to change the ews system after u did the try and error thing. cheers[/QUOTE
EWS error has been faced:
1. e39, the car stopped at a place after that not able to start the car. This is my friend's friend's car. After i checked the car, found that ews error. He got 1 pair of DME and EWS. After he changed it then i make the chip to start the engine. Until today non of his forman able to find out what is the root cause the EWS error. I checked the EWS only data corrupted not damage on the circuit board. This EWS still can use if load other EWS backup data into it.
2. e53, happened recently. The owner claimed that send to an accessory workshop after that cause the battery terminal burned. After that EWS error not able to start the car. Asking my help to make the engine start. After the conservation with the owner(Ahmad) confirmed is EWS data error and not damage on EWS. I recommend him to a workshop to pair back the EWS with DME.
3. e38, this is the case that you mentioned above. This case is very similar with case 1. While i unplug the EWS, the owner beside me. What is did is only unplug the EWS after EWS data error occurred. At the beginning the owner blamed me causing the EWS error. After that a Malay uncle seem knew alot of things about BMW car tried to talk to the owner. That malay uncle really knew some BMW things more than i do. After that i called a carreer to send the e38 to his workshop.
Case 1 and Case 2 both EWS are not damage. Case 3 also no damage. I have checked it using my machine. It still can load data in. If that moment manage to have backup data then can load it back and start the engine.
I am very sorry for the Case 3 happened.
Before all these cases happened, i had told all the ppl i met about the cases similar above. I have helped some ppl to backup the EWS data to prevent the cases above happend.
I helped ppl backup EWS data which is FOC. Even if the EWS data corrupted and asking me to load back the backup data to EWS also FOC.
Ahmad has booked me to help him to backup the EWS data. If anyone really wanted to prevent the cases happened above pls contact me.
