water leak into cabin
moots
Last Friday in a heavy downpour,a passenger sitting at the LH rear seat had a mini waterfall on his left shoulder.The water came from here:
So straight away me thinks the sunroof drain is clogged up.Tried blowing thru from top but totally clogged.
So went to the other end:
And this was the cause....it was all gummed up after 10 years.Did a thorough cleaning with water and all is well again:
:69:
Moots,
Please explain a little more. The leak comes through the cabin ceiling. How is it connected to the wheel well ?
Thanks for reading.
tckhor said:
Moots,
Thanks for reading.
alamak bro...sorry.
The sunroof assembly has 4 drain points at each corner.The pic shows the LH rear corner and this drain hose is routed to drain into the LH rear wheel well.
The white rigid drain tube is on the sunroof assembly and the black flexible drain hose goes all the way to the wheel well.
ha ha....that's the latest in performance braking upgrade....
that wan is my torch light...LED hand held with magnet behind
hahahaha.....u got me there!! if its some sort of performance enhancing thing wld hv jumped straight right in!!
