bmw7833;694696 said:Look carefully the door edge, it should have some water mark there.
To check whether the water come from the door seal, close the door and spray water to the door, check the carpet wet or not.
aisey...don't lar check laidat.....carpet wet got stinky stinky smell wor......
pour water with garden hose on the window with the door OPEN.
if you see water coming out between the door card and the door frame,then your water barrier is not sealing properly.if it IS sealing properly,the water will drain out at the 2 drain holes right at the outer edge of the door's extreem ends.
