Very noisy at my door panel !!
ZeNeGeR
Guys,My 325 e36 very noisy after install tinted film. What happen was the accessory felor break both of my rear door panel clip. My 325 is old and i look at the material is like wood paper, if i m not mistaken there is about 8-10 clips unfortunately 1 clip melt (maybe is too old already the wood paper break) so wat happen now is both of my door panel out of 1 clip making alot noise when drive slow about 20-40kmh at un even road. Anything can help reduce noise beside change the door panel. And if is a chop shop door panel how much it cost ??
you can buy the door panel clip at the spare parts shop. Cheap cheap.
Originally posted by ZeNeGeR@May 11 2005, 05:07 PM
the problem is not the clip is the board (the hole koyak) cant hold the clip.
Get the clips and than use epoxy to bond the clip to the board. That would do the trick.
Musclehedz: thank you for ur advise... This must be DIY right ? hmmm still not too sure but i try to consult foreman to sort this out...
Yup, DIY.. the cheapest solution... or another way is to get another panel from the chop shop
i want to DIY. la wanna join we can do it together so that is not so boring mah....
i dunno from wherer to start also unless u know than i can join lah hahaha
Musclehedz can show us ?
show me the board panel first dudes...see what the damage is like first.
i got some clip from the chop shop in damansara . in dont think is enough anyone know where to get it some more
