Tyres + Brakes + Servicing
EZ_Raider
My dearest Sifu's, I've got an E46, 2000 & recently it began to wobble a little. I went to a Tyre shop at Ampang Jaya & they recommended me to change my tyres (recommedning some Korean brands) immediately & fixed a price of RM580/- with no discount :(.I called up some friends and they advices me to go for Falken or GoodYear GSD2 (made in Germany/Thailand) but after reading your forum, i've doubts.As for tyres, i'm currently using Yokohama, Z series 17" (can't remember the details as it's raining outside)I've a few Questions :1) Where is it best place to do the On Wheel Balancing & Alignment?2) The price range of the On Wheel Balancing & Alignment?3) What sort of brake lining do you guys recommend & it's est. cost?4) My car had just done 100k, what sort of service is the BEST recommended service & where?5) Where would i be able to get Yokohama Tyres in KL & Selangor?Appreciate your responce... :)Cheers,EZ_Raider
Ezrider, got this from johnchen under 'techs and engine' forum...
this could help you...maybe :D
I'm quite intersted from what johnchen wrote here...but I haven't give a try yet...hehe... :wink:
johnchen...borrow your writeup to help our fella... :yahoo:
“Last Sunday afternoon on the way to the KLIA, my iDrive tire puncture warning poped up. That's the first time its happened to me. So I slowed down and turned back since I wasn't far from home in PJ. I was driving at around 120-130 km/h when it happened. No scarry moments. I continue to drive at around 100km/h back.
I then drove to a tire shop that I saw recently renovated and open at Taman Megah, Tyrezone, a Michelin dealer (www.tyrezone.com.my). They have brand new latest equipments. More on that later. The young boss name is Gary and the head mechanic is Calvin. If you go there, make sure Calvin is there to tend to your car. Both of them are very friendly and spent time to explain to me what each equipment can do and what was wrong with my car.
They checked my tire and found a 2" nail in it. They mended it using the inside-out mini seal (RM35). They had to remove the tire and the seal pushed in from the inside of the tire. Normal (RM5) seal is the one pushed in from the outside. This is much more secure.
Since I was there I did the full monty for my tires; alignment, balancing and rotation. What impresses me most about this place is not only that it is new but all the equipment are the latest. Here's what they have:
(1) Hunter GSP9700 Road Rage with Straight Trak Tire Pull Measurenment. Cost per tire is RM15. This machine is very sophisticated and the owner says there's only 2 such machines in KL right now. It measures a heck of a lot of stuff. This machine more than balances the tires and will also tell you which tire is best suited for which side of the car. It took them 1.5 hrs to balance all 4 tires! They had to remove the tire from the wheel many times to turn and match the tire's high point with the wheel's lowest point for a perfect balance and minimum roll resistance!
(2) Butler Airdraulics Evo Series. This machine is a tire remover (from the wheel). This latest model which is best suited for expensive alloy wheels as all the parts are rubber coated.
(3) Hunter DSP 600 alignment machine. This is again the latest model which uses infra red to measure the 4 wheels instead of wires. It has all the lastest cars' configuration/settings programmed in there, including the E60, E65, E90, and all the older BMW models too. It has the setttings for latest 2005 Porches 996 turbo quattro car too!! They gave me a print out of my car's before and after settings (toe, camber, caster, etc) for my record which can be used at other alignment shops too if I'm happy with these settings. Nice touch. My record is stored in that machine's computer and can be recalled on my next visit. That cost RM50 for front and back alignment. Camber adjustment is another RM35 for each wheel if it is needed. Mine needed only on one side.
(4) The final thing I went for is the nitrogen air instead of normal air for my 4 tires. That cost RM5/tire. Future refills is RM1/tire. There are people who thinks it is not necessary but what the heck, its only RM20 which can't buy me a jug of beer! Properties is that is runs cooler, holds the pressure better, lower milage, etc. Ehh...I kiasu lah!!
My advice to all of you is to go check your tire pressure every month. I found out that my tire pressures was low which had caused pre mature uneven wearing. The alignment for rear left was out which translated to wear on the inside more than outside. My car has 13k on milage. Should have sent it earlier. These run flats are bloody expensive!!
Again, another advice to all who sayang their car is to send your car for a tire check every 8k-10k km. Even a brand new car alignment may not be accurate. Mine could have been out from the day I took delivery! If you are running on expensive tires, go have the alignment and tire pressure checked now.”
Just changed my front tyres to Falken 225/45/zR17 last week.
Forked out RM480/pc inclusive of installation plus balancing.
Maybe still early to say but so far so good.Softer and quieter ride ,imho.
My previous tyres were Continental/Germany.already quite worn out (>50%) and needed change .
Anyone had any bad experience with Falken tyres before?
Care to share yr opinion?
Which falken, the zeix is so so only, GRB is very good, ST115 is good but once it worn off more than 60% not so good on wet.
I wun touch FALKEN for my BMW .. Japs car is fine.
The ONLY FALKEN that suits the BMW (my opinion) is the GRB RS TUne II - stop production I tink.
My observation;
1) Too hard - coz I am running on sport suspension
2) Noisy
3) So-so if it rains
4) And the worst one - it follows the contour of the road. I hv to keep on correcting my steering ..
Depending on your budget, I would recommend the Bridgestone Potenza GIII. I use the Potenza S-03 (which came with the car) but I don't think I can afford to replace them after this round. The GIII's I was told is quite good, silent, good overall grip and harder wearing than Goodyear of the same class. Personally, I have tried the Potenza RE711 which was the predecessor of the GIII. Perhaps you should ask if there are any users of the GIII and what their opinions are.
Yup,
Can concur. Falkens are a tad too noisy and have been known to "kaboom".hehe :lol: That's just personal experience lar. Might be suitable to some other ppl though
Hi Birthday Guy!
Looks like I just have to bear with those Falkens till next change... :p Thanks any way.
EZ Raider,pardon me for the sidetracking........
must be those new tyres on my ride ....following the contour i think :D
i am offering to sell brand new silverstone 235/40/18 at only RM400 each. manufactured June/July 2005! cheap!!!
:yahoo: ....
Hi Sifu's, thank u very much for your inputs. The write up was excellent. It has really help me in making some good decisions soon.
I'm currently using Yokohama AVS ES100 215/50ZR17 91W (please visit http://www.yokohamatire.com/pdf/avses100.pdf) where u guys can verify the technical specs. Is anyone currently using a Yokohama and feedbacks r welcome.
As for servicing, i thought of doing it at Checks (Sungai Besi) any idea on the service realibility or do you guys recommend me some suitable realiable service centers?
Cheers,
