Recently noticed that while breaking, i can feel the tyre vibration or little bit sterring shaking. Already chk to Authorised BMW w/shop. still no answer till now. Pls advise..
if only all of the above problems solved but you still facing the vibration problem....please check your TIE ROD END, it is said that most people has been misleading the problem with the warp disc.
Its a must to change new brake pad s when u change/skim disc's... Just to make sure any un-even surface on old pads from faulty disc doesnt damage ur new disc, causing lines and squeaks...
