Tyre pressure sensor?
c-square
I just changed my run-flat tyres and when they removed the old tyres from the rims, I took a peek and try to locate where the sensor which gauge the tyre pressure (the sensor that inform us when there is a pressure loss in any of the tyres) and I couldn't find any. Can anyone let me know where are those sensor located?
it is located at the valve where you pump the air. make sure that the tyre shop change this special valve.
attachment.php
Thanks for the pix, Jarance.... but I don't think my original wheels come with that device. When the tyre shop pried open those worn out original Bridgestone tyres, I original air valve looked like any other ordinary rubber ones. Don't have that square black-thingy wor. I asked the tyre shop (Speedline @ Kota Damansara) fella and he said the it uses "Infra-red" to gauge the tyre pressure. I am a bit sceptical on that infra-red explanation, so I thought of asking here to get a better understanding.
on the E60 it uses rotating speed of each wheel to detect deflation. There is no sensor on the rim. Not sure which model of BMW you own.
Thanks sixpotter for the possible alternative perspective. Mine is a F30. Could be the same as the E60
