TPM reset step ?
ansonsoo
The reset procedure should be...1. Check Tire Pressure to make sure no variance from side to side.2. Sit in car, with out touching the pedals.3. Key in ignition, Turn key on to engine off position (second position).4. Press and hold TPM until TPM lights go out completely on the dash.5. Press and hold TPM again until yellow TPM light indicator comes lit on dash.6. Start car and drive. Light will go off itself once it has calibrated tire pressure.Correct me if different step ?!
i guess its the correct procedure, i had a problem once but it went off after several on/off buttons..
do you know SMG can reset too ?
Hi M-Boy, ops sorry..:laugh: e39-boy, why not just share with us reset step for the SMG please...:top:
i read somewhere is M3forum.net that we need to drive our car at 75-80 kmh.. then just pull both paddles for 2-3 seconds.
it automatically erase the adaptations and log new ones.
i think its almost the same as the e39 525i auto gearbox sport mode thing. 30 seconds on knock down accelerator and brakes before starting the car.
still adapting to this car so i cant really tell if there were any difference.
