ansonsoo
- Feb 17, 2011
- 446
The reset procedure should be...1. Check Tire Pressure to make sure no variance from side to side.2. Sit in car, with out touching the pedals.3. Key in ignition, Turn key on to engine off position (second position).4. Press and hold TPM until TPM lights go out completely on the dash.5. Press and hold TPM again until yellow TPM light indicator comes lit on dash.6. Start car and drive. Light will go off itself once it has calibrated tire pressure.Correct me if different step ?!
