Vincent Hor
- May 28, 2005
- 1,363
Forgot to mention, also do a pressure test. You will need some special tools secured over the radiator cap. Apply pressure via a hand held pump. If there is a leak, you will see coolant seeping out. Otherwsie, take a torchlight and carefully scan through all the hoses especially at the joint areas. Check the water jackets core plugs too and also the water pump area. Tell tales signs of leakage is a streak of yellow/brownish stains.
