Tie Rod E30
anxious
When to replace and how much :- Tie Rod E30?Last week I want to align my wheels and the tyre shop guy said there was some freeplay and that I should check my car first.Today my mech told me that there is a slight play in both my tie rod.Hence my Q?
depends on the way you drive, road conditions and some what luck, especially if u get those once in a lfetime terminal goods that has defect
the rod has 2 type of freeplay
1. ball joint
2. inner joint
usually one of it will give way first, either or, it still needs replacement
you will find that ur alignment will be out of wack after a few weeks of alignment - signs of wear n tear
vibrations, even very little can cause accelerated wear n tear of the rods
another misunderstood signs that the tie rods are going is actually the steering assembly that has internal freeplay
my advise is got get independant evaluation, some people will go with the flow, so don't say anything, just ask to check if ok or not, and see how they check.......
Thanks, I think my mech quoted me RM175 per piece.
Since I have had knock out bills over the last month, I am reluctant to change it unless absolutely necessary.
new RM175 is good price... used one but in good condition cost RM100 per piece... worth to buy NEW @!!@@!@!
anxious dude,
mine is also out .....in my case ball joint + tie rod..... went to Sunny in Tmn Mayang over weekend to get car aligned etc. and was pointed out problem...... anyone know of a good place to get this done? ....need this done fairly quick coz car not aligned properly at moment ...thanks!
Jip,
If tie rod....the one which is attached to your front wheels ( one rubber boot, it's pretty cheap. common item to replace and yes, it must be in good shape ( no free play ) for a proper wheel alignment.....
If u keen, will check bill & sms u the price..
My mech charged me RM270 for 2pcs tie rods (excluding installation). Labour fees not sure coz he lump sum other jobs in 1 bill. I think he got the parts from 1st Division.
A spare part shop in BW quoted me RM160pp.
Anyway I managed to align my tyres as 2nd tyre shop guy confirmed not much freeplay.
I'll probably change both tie rods before I change my tyres later this year.
