Changing the OBC language:The OBC language of the car will sometimes reset itself to German. To change it to whatever you like try this:1. Turn the ignition to position 1.2. Hold the Right cluster display button down for 10 seconds. Then the next language will appear.3. Repeat this procedure untill you have the desired language.4. U need to do it 7 times as there are 7 languages before u can get English..
